I'm ready to give CodeProject.AI a try... Install instructions?
105437
BIT Beta Team
Jun 8, 2015
2,242
1,090
I'm currently running DeepStack and would like to try CPAI. Is there a post somewhere that has the install steps/instructions? Thanks!
There’s a massive thread on this in which I think you’ve actually posted, is a bit of a read but lots of useful info in there.
Yeah, I searched for a while and couldn't find the info I was looking for. Thanks!
See the below link
If you are using a GPU you need to install CUDA and run the cuDNN install script first
If you are using CPU then just install the latest
Thanks. I'll check out the link. I'd like to run the GPU version.
Also, I have a QNAP NAS and I ran Deepstack on it. I think I'll try it there first.
See the below link
I just ran the Code Project AI install and my 2060 worked out of the box. It setup the entire dashboard as GPU. I didn't even know I was supposed to install CUDA. I'll have to look into that.
Reactions: 105437
Did you have CUDA install before for DeepStack?
I don’t recall doing it for anything before. Used as my main desktop and light gaming. I haven’t had time to test fully yet. All I did was install CP AI and run the benchmarks. Haven’t actually used it for BI yet.
If you go to the dashboard does is show you are using GPU(CUDA) or just CPU?
Reactions: larry117
Here is my screenshot:
No CUDA installed at all. Just the Nvidia Geforce Experience Drivers. Running a GTX 2060
So I just pointed BI (which I run in a VM) to Codeproject AI to my desktop with the 2060 in it and now I'm getting ~50ms inference times which is excellent! The BI VM running with just the CPU has been giving me ~750ms times using @MikeLud1 ipcam-general model. That is a big difference.
Just installed everything. The CPAI service isn't starting automatically. How can I fix this? Also, I see no mention of GPU in the status page after installing everything.
I'm getting closer. How do you tell CPAI to use ipcam-combined custom model? Here are my settings, I would appreciate a peer review.
Thanks @MikeLud1, I made that change and restarted the BI service. I have noticed that when you restart the BI service, it doesn't restart the CPAI service. After manually restarting it, here's what I have.
Yes, that works. I noticed a v1.6.5 notice in the CPAI dashboard. I tried the download but it didn't work.
Just downloaded it. They must have not had the link right when you attempted. Trying to find the release notes though is a pain since the codeproject web page is a bit of a mess.
Reactions: jrbeddow
What's New - 1.6.5.0
  • Patch 1.6.5: Multi-setting updates via API, ability to force half-precision support, YOLO nano-sized model added
  • Patch 1.6.2: Fix for more nVidia cards, MODE=High bug fix
  • Patch 1.6.1: Catching issues on pre-win10 machines, fix for GTX 1650/60 cards
Where did you find this? Browsing their source code, they don't even have any changes after 1.6 which is eight day old: GitHub - codeproject/CodeProject.AI-Server: CodeProject SenseAI is a self contained service that software developers can include in, and distribute with, their applications in order to augment their apps with the power of AI.
Where is the repo for the 1.6.x releases?
I agree that their website is a bit confusing, and I can't address your repo question at all, especially given the way that this installs, on Windows anyway. We in essence only download a stub, which then retrieves the rest interactively.
Anyway, your release notes are found halfway down this page:
Reactions: actran and biggen
