Infrared light issue
Mar 27, 2018
18
17
Raleigh, NC
Hi folks,
I have two WGCC PTZ tracking cams that have been great going on 4 years. Last month I noticed I didn't see the obvious four red lights on one of the camera faces at night. Everything else works though. Has anyone serviced or replaced the IR lights? Mine is out of warranty. Any thoughts? Thanks, Jim
Assuming the daylight image is in full color, have you logged into the cam's webGUI to insure the IR settings are as they should be (same as the properly functioning cam) ?
Actually I simply use the presets to make changes. That's a good suggestion. From reviewing the video on the NVR, it simply simply stopped working. I'll try logging directly into the ipcam. Thanks, Jim
Reactions: sebastiantombs
I disconnected from NVR, plugged into a smart switch, changed the ip address and subnet mask and gateway with SAPD so I could access the webGUI from my laptop. Everything seems right. I changed a few things to make the IR lights to go on but no luck. I can change from day to night mode with no issue, I just cannot make the lights go on. Jim
Reactions: TonyR
Some cameras that have 4 LED are 2 for near and 2 for long, and the 2 for long do not kick on until the zoom is a certain amount, so make sure when you were looking at it that it was in a state such that all 4 should be on.
Reactions: TonyR
I took the WGCC down and put small ipcam in its place. Tomorrow I'll start taking the WGCC apart. By the way, I posted earlier about building wooden mounts. Nearly 4 years and the mounts are still sturdy and don't require paint.
