Install Code Project then BI?
Dorsey Pender
Sep 7, 2019
217
30
San Francisco
I’m installing to a new server and is it recommended to install CPAI first then BI or the other way around.
I installed CPAI and it won’t start Yolov5 .NET which is running fine on my other server.
Also the old server has Yolov5 .NET running on the GPU.
The new server install only shows the option to run on CPU but won’t start.
The new server install has a fresh copy of Windows 11.
1. What might be the issue as to why it won’t start on CPU?
2. Why doesn’t it show as GPU?
Intel Graphics UHD 630
Prodesk 400 G6
I don't think that CPAI will use the Intel GPU, it only works with Nvidia based GPU's, if you use the Dot Net module for CPAI it should work just as good; possibly better running on the CPU! Also if Yolo5.net will not start, you will have to look in the CPAI log to see what the errors are that are being reported, other wise it will be next to impossible to make any suggestions as to the problem!
I will reinstall and let you know.
I installed 2.9.5 and it’s working. I had a copy of 2.8.0 and it doesn’t work with Windows 11 for some reason. On to the next obstacle. Thanks!!
