IPC-Color4M-TL
This is the TIOC Pro
As I originally suggested, it would be good for your inside corridors. 3.6mm model
Fair warning, some of the Dahua Camera's are quite blurry close range, so pay careful attention to the min focus distance
2549:
2.8 mm: 1.7 m (5.58 ft)
3.6 mm: 2.6 m (8.53 ft)
3449:
Close Focus Distance2.8 mm: 2.0 m (6.56 ft)
3.6 mm: 3.5 m (11.48 ft)
Reactions: quiet.tea
2549:
3449:
True, but on the 3449 pro 3.6mm I find it to be closer to 1/2 of that
That's great! I currently have a couple IPC-T54IR-ZE (4MP 1/1.8" image sensor) cameras in my backyard, which is in total darkness at night. The IR on those cameras just don't cut it. They illuminate a circular area, and all around that it's dark. I need to see a wider area. Do you know if the IPC-Color4M-T would do that? I'm thinking of external lighting but am hoping one of Andy's cameras would do it instead.
In my backyard I have a camera mounted high at the top of the house and looking downward. As with your photo, it is in complete darkness and with a T54IR-ZE-S3 the IR illuminated a bright spot in the center. I won a Color 4M-T in Andy's lottery and replaced the T541R with the Color 4M-T. The IR is much more balanced and spread. The Color 4M-T is a great camera.
