IPC-T5442T-ZE missing zoom
bethzur
May 19, 2021
106
57
Pennsylvania
I got an EmpireTech IPC-T5442T-ZE via Amazon from the most recent sale. I'm trying to configure it, but there is no UI for the varifocal / zoom. Trying to zoom in BI also doesn't work. This is right out of the box.
Use find/inspect in the video configuration tab and accept what it finds. Enable ONVIF there as well. Make sure PTZ is enabled on the cameras' config in BI, a separate tab in the camera configuration. Remember a varifocal is not a zoom camera and is designed to be set and left at the desired zoom level. The zoom mechanism is not built for constant use.
Neither. You should make all adjustments on the camera.
But until you learn the hard way why that is, On the NVR and DMSS you go to the live view and set the zoom.
On DMSS click the bottom left icon
Then use the magnifying glass icon at bottom
Yes, login to the NVR
Go to the Camera registration page
Click on the blue IE icon for the camera you want to adjust
You know how to login to the NVR via a web browser?
This is a bit old but still mostly correct.
Go to the right and hit the plus or minus it right click hold on the circle slider and move it.
Reactions: Mike A.
Nobody seems to understand the new UI
CLICK ON THE LITTLE HOUSE ICON TOP LEFT
This will open the full top level menu to the camera
