IPC-T54IR-ZE-S3 configuration notes with blueiris
chain
Feb 29, 2020
48
7
great white north
What are optimized setting for the camera and blue iris when using these camera's. Do you uses code project setup and camera ? Or is there a recommended solution for night
Night setting
Brightness 57 Contrast 64 Saturation 50 Sharpness 50 Gamma 50
Shutter 13ms gain 68 Exposure 50 2D/3D 45
Blue Iris simply takes whatever video feed it is given.
Most of us have found the AI of the camera to be more than sufficient. It comes down to do you want an orange box around the object and do you want to detect on more than just person or vehicle.
In terms of getting the most out of the camera, here is my "standard" post that many use as a start for dialing in day and night that helps get the clean captures and help the camera recognize people and cars. But every field of view is different.
Start with:
H264
8192 bitrate
CBR
15FPS
15 iframes
Every field of view is different, but I have found you need contrast to usually be 6-8 higher than the brightness number at night.
We want the ability to freeze frame capture a clean image from the video at night, and that is only done with a shutter of 1/60 or faster. At night, default/auto may be on 1/12s shutter or worse to make the image bright.
In my opinion, shutter (exposure) and gain are the two most important parameters and then base the others off of it. Shutter is more important than FPS. It is the shutter speed that prevents motion blur, not FPS. 15 FPS is more than enough for surveillance cameras as we are not producing Hollywood movies. Match iframes to FPS. 15FPS is all that is usually needed.
Many people do not realize there is manual shutter that lets you adjust shutter and gain and a shutter priority that only lets you adjust shutter speed but not gain. The higher the gain, the bigger the noise and see-through ghosting start to appear because the noise is amplified. Most people select shutter priority and run a faster shutter than they should because it is likely being done at 100 gain, so it is actually defeating their purpose of a faster shutter.
Go into shutter settings and change to manual shutter and start with custom shutter as ms and change to 0-8.3ms and gain 0-50 (night) and 0-4ms exposure and 0-30 gain (day)for starters. Auto could have a shutter speed of 100ms or more with a gain at 100 and shutter priority could result in gain up at 100 which will contribute to significant ghosting and that blinding white you will get from the infrared or white light.
Now what you will notice immediately at night is that your image gets A LOT darker. That faster the shutter, the more light that is needed. But it is a balance. The nice bright night static image results in Casper blur and ghost during motion LOL. What do we want, a nice static image or a clean image when there is motion introduced to the scene?
In the daytime, if it is still too bright, then drop the 4ms down to 3ms then 2ms, etc. You have to play with it for your field of view.
Then at night, if it is too dark, then start adding ms to the time. Go to 10ms, 12ms, etc. until you find what you feel is acceptable as an image. Then have someone walk around and see if you can get a clean shot. Try not to go above 16.67ms (but certainly not above 30ms) as that tends to be the point where blur starts to occur. Conversely, if it is still bright, then drop down in time to get a faster shutter.
You can also adjust brightness and contrast to improve the image. But try not to go above 70 for anything and try to have contrast be at least 7-10 digits higher than brightness.
You can also add some gain to brighten the image - but the higher the gain, the more ghosting you get. Some cameras can go to 70 or so before it is an issue and some can't go over 50.
But adjusting those two settings will have the biggest impact. The next one is noise reduction. Want to keep that as low as possible. Depending on the amount of light you have, you might be able to get down to 40 or so at night (again camera dependent) and 20-30 during the day, but take it as low as you can before it gets too noisy. Again this one is a balance as well. Too smooth and no noise can result in soft images and contribute to blur.
Do not use backlight features until you have exhausted every other parameter setting. And if you do have to use backlight, take it down as low as possible.
After every setting adjustment, have someone walk around outside and see if you can freeze-frame to get a clean image. If not, keep changing until you do. Clean motion pictures are what we are after, not a clean static image.
I'm not sure when I set all the camera with the same setting. Only one of the camera's goes to BW, where the other camera remain in colour mode during the day. 4ms exposure 30 gain. what is causing the issue?
For whatever reason that camera deems it has enough color and the other cameras do not.
If you want color at night, you can force it into color by going to day/night and taking off auto and making it color.
If you will not be using CodeProject then yes you can uninstall it.
Your mainstream is
H264 or H264H
CBR
8192 bitrate
15 FPS
15 iframes
If so, then you need to up the bitrate. That is used as the starting point and then we go up and down until we don't see a difference. Running higher bitrates that do not improve the image results in using storage faster. Some of my 54IR-ZE cams are 4092, some are 8192 and a few are in the 10240 range.
That looks like substream. Is that from the camera solo'd or did you snip from multi-camera view?
Up the receive buffer to 40MB on the BI camera configuration page.
And you don't have Smart Codec or something else going on?
You are recording direct to disc?
Post the camera GUI screenshots of the settings.
please see reponses
see video
change that setting
I belive no
no
