Mike A.
- May 6, 2017
- 4,209
- 7,097
Have updated the firmware, which reboots it, not sure if that works similar to a reset but also not sure why resetting would help as I haven't changed a setting on it in years!
Things can get corrupted independent of any change you intentionally make. New firmware may carry over previous settings. Set it back to defaults and go from there.
The POE adapter should help rule out a problem with the switch.
