- Apr 13, 2016
- 542
- 240
I'm still fighting against iVMS 4200, on win7 64 bit..... :livid:
Latest news ... after having tried a lot of things, uninstalled, manually cleared all, cleared the registry, re-installed, tried older versions.... now here's what happens:
the iVMS-4200 (2.5.0.3) correctly connect to the DS-7600NI-I2/08P, all seems working well, but after a while (could be 5 minutes or 5 hours), if I click on 'Switch to Instant Playback', I see the playback, but as soon as I click on 'Switch to live view' the image freezes, and if I click again on the same command, windows tells me
'iVMS doesn't respond', and I have to close and reopen it.....
The ClientLog.Txt (in the iVMS directory) says
While on my old laptop, win7 32 bit, the same software seems working without any issue ...
What could I try ?
Cheers,
jonatha
HTML:
[2016-05-10 21:12:08,861][Zhuz][INFO]InitFullScreenLockWidget Success.[..\..\..\src\iVMS-4200v2.0\ui\IvmsApplication\IvmsApplication.cpp(618)]
[2016-05-10 21:12:09,583][zjw][DEBUG]Failed to resolve ACSClientEx interface[..\..\..\src\UiDataController\ACSClientSystemMgr\ACSClientSystemMgr.cpp(375)]
[2016-05-10 21:12:09,599][zjw][DEBUG]Failed to resolve ACSClientEx interface[..\..\..\src\UiDataController\ACSClientSystemMgr\ACSClientSystemMgr.cpp(375)]
[2016-05-10 21:14:54,048][yx][ERROR]Failed to set NET_DVR_GetDVRWorkState_V30, userID: 0[..\..\..\src\EncodeDevicePlugin\logical\NetworkComm\DeviceSDKComm.cpp(1308)]
[2016-05-10 21:15:12,574][[PGT]][ERROR]failure to CCapabilityApp::GetBasicCapability, userID = [0], error code = [151][..\..\..\src\CapabilitySet\BasicCapability.cpp(62)]
[2016-05-10 21:15:12,622][[PGT]][ERROR]failure to CCapabilityApp::GetRecordAbility, userID = [0], error code = [151][..\..\..\src\CapabilitySet\RecordAbility.cpp(62)]
[2016-05-10 21:15:12,751][[PGT]][ERROR]Failure to CCapabilityApp::GetFishEyeAbility, userID = [0], error code = [151][..\..\..\src\CapabilitySet\FishEyeAbility.cpp(88)]
What could I try ?
Cheers,
jonatha
