IVS in dmss playback timeline???
rufunky
Dec 2, 2015
719
251
Is there a way to enable IVS to show in dmss playback timeline??? The latest version doesn't seem to be doing this by default. Filters show nothing only general shows 1 completely green timeline...
Did they change it?
I never upgrade until I have to
In playback click the little icon to the right of the date in the middle of the screen,
Then check Intelligent to get only IVS. Or ALL to get the blue IVS lines within the green general recording
Reactions: rufunky
Thanks bigredfish
Yes, they changed it a bit. I don't see a separate AI icon. Looks like the only options are through the filters which yield no results...
Mine show now. For awhile it appeared they didn't, but the April 9th update on Android fixed it.
Reactions: rufunky
What does ALL get you?
Maybe I need to clear both cache and data from app.....didn't want to have to re add all systems again
Can you share a screenshot of playback showing IVS? I cleared the cache and data and uninstalled and reinstalled the app. Re-added all my cameras ended up with the same results...
Here you go, sadly the images below are generic and not camera specific, but it seems to work correctly for bigredfish in older versions (mine never has)
Reactions: rufunky
Yeah, mine doesn't even show the IVS lines nor under events. Does yours show anything under events?
Sorry I just saw this was Android.
I use iPhone.
Mine shows, There is 1 thing however... If you zoom into the time line it shows better. When zoomed out you can't really seem them.
Edit also added picture, mine shows event as well
Reactions: rufunky
I zoomed in and still had nothing. It's so weird. It's like there is an activation setting missing
You running ip setup or p2p? I will admit mine is P2P. I remember before they said no events would remain in events once checked if on IP. Mine is on Samsung S21 Ultra
I'm using P2P (because I don't care if strangers watch my cams lol)
Couple of things just thought of,. Did you setup to record your IVS? Go to the Camera or NVRs, storage, and check the Schedule and make sure that you are not just setup to record full time. If you don't have Events, IVS, Only have Full time in the schedule then no recordings will show up in the recorded time line?
In my camera only record events in the Micro SD card.. So IVS shows up in the time line of the Camera.. But if only Full time and Alarm or Event isn't enabled then only full time will record..
