License Plate reading image
105437
BIT Beta Team
Jun 8, 2015
2,242
1,090
This is the alert image from the built-in AI. Does that mean it didn't continue evaluating images to see the license plate? None of the three images from this trigger show the license plate. What can be done to correct this? Thanks!
Clone this camera and just have the clone camera do the license plate reading only, not object detection. Use the main camera for object detection only.
Reactions: 105437
I'll try that, thanks. I thought about putting DoNotCancel in the To Cancel field to see if it would consider subsequent images for LPR. So uncheck "Primary Object Detection"?
Mike I see you post often of LPR. I just can’t see to get mine to work with new built in AI.
Do you have or know where step by step instructions are?
See if this helps
Reactions: Arjun
My LPR isn't working because when it captures a plate it looks like this. Do I need to use the main stream for LPR? Thanks!
