Hi folks,
After a recent break in where we couldn’t identify the license plate we decided to add an LPR camera. I’ve researched and it says I should be within 30 degrees on the vertical axis and within 15 degrees on the horizontal axis. The vertical axis isn’t a problem, but the horizontal one is. My house is setback 40 feet from the road and 54 feet to the middle of the road I would need to target. Using some trigonometry, that gives me a minimum capture distance of 208 feet (54/sin(15)) from the camera.
While that street is long enough to do that (and it actually kind of provides better coverage), I’m not sure the Loryta IPC-HFW5241E-Z12E I have will do it at that range. The camera specs have a DORI identify value of 289ft, but 200ft is pushing it for LPR based on what I’ve read (and the Amazon page says LPR at 120-140ft).
I don’t have a way to get this closer to the street, so I have 3 options:
1. Target 208 feet, and hope for the best.
2. Target 115ft (between 115 and 160 is blocked by a fence), but that gives me an angle of 28 degrees - seems likely to be too far off angle to work.
3. Find a different camera with longer range (any suggestions?)
