Mike A.
- May 6, 2017
- 4,209
- 7,097
1/120 is fast enough to get a person moving pretty well but likely won't be enough to get a vehicle going by quickly. Yes, it will get much darker as you step up. You've already got a good cam with a good sensor and sounds like you're pushing gain already so likely the only real good answer is to get more light out there. Turn Smart IR off and IR to manual and 100% may help some. The DI10 is very wide. Maybe try turning it a little more in that direction and that might help without hurting what it's lighting now. Backing up the zoom a little also might help some.
Not sure what your purpose is for this cam. You seem to have kind of a neither here nor there use case. You're not trying to get plates where you could turn shutter up and forget about it being dark for the rest. But you still want to stop motion well for something crossing a relatively narrow field of view quickly and near perpendicular so that makes it more difficult.
You might also try shutter priority mode set high and let the cam do its thing as far as the rest. I've had some mine where that seemed to look better that way at least in terms of overall average view.
