Hi All,
Really hoping you can help me. First post here but i've been reading these threads for years.
We run a CCTV system at our secondary school that was originally only meant to be a few cams. Its grown horrendously to over 100 camera's, and as we've added camera's, we have added new 'servers' to accommodate.
Recently we set about streamlining these as we had 5 servers each only able to cope with around 20 cameras. I read this forum and others and learnt about substreams, D2D recording and more, which has helped me get everything running much better.
However
We still have one major issue which is a huge problem. Trying to watch back clips is almost impossible. The footage just won't play, and skips frames constantly.
I've run some troubleshooting, and the camera's are recording fine. I set the recordings to MP4, and the footage is perfect, no dropping, smooth playback and great to watch. This suggests the issue isn't with the actual footage. We record continuous 24/7, with no motion detection, no alerts, no processing at all. We have one machine dialled in via webinterface just to monitor for camera drop outs etc.
When using BVR, on the BI interface, the same footage is useless. Its skippy, jumpy and just unwatchable.
What am I missing? Or what can be done to solve this?
For information;
Blue Iris 5.4.4.3
CPU usage 54%
RAM usage 8GB
Machine;
Windows 10
CPU i7-9700k
RAM 16GB
Camera's; 39 total.
All Foscam, Mixture of models including FI9961EP (1080p), FI9853EP (720p) & C1/C2
All camera's wired, on fully enterprise level network.
Substreams enabled on most. FPS max 15 on all.
Please help! Its driving me round the bend. Finally got the server running smoothly with all the camera's, however if the footage is unwatchable then we'd have to go back to 5 servers with less camera's each. The plan was to have 2 running 40 each (identical 9700k's w/ 16gb ram) but that doesn't look possible.
However
For information;
Blue Iris 5.4.4.3
CPU usage 54%
RAM usage 8GB
Machine;
Windows 10
CPU i7-9700k
RAM 16GB
Camera's; 39 total.
