Messages in Log File "Display Change"
tward392
Sep 9, 2019
255
145
US
Can't find any information out about what this message means, getting it a lot in my log:
0 9/30/2019 1:43:48 AM App Display change
0 9/30/2019 1:43:49 AM App Display change
0 9/30/2019 1:44:02 AM App Display change
0 9/30/2019 1:44:03 AM App Display change
0 9/30/2019 1:44:58 AM App Display change
0 9/30/2019 1:44:59 AM App Display change
0 9/30/2019 1:45:53 AM App Display change
0 9/30/2019 1:45:54 AM App Display change
0 9/30/2019 1:48:00 AM App Display change
0 9/30/2019 1:48:01 AM App Display change
What APP are you using or what device is pushing this, better you give more info and background of the gear you are using.
Blue Iris 5, not sure what app is pushing the message. The messages are in the Blue Iris status screen and in the file that Blue Iris logs to as well. I just assumed the "App" meant it was coming from Blue Iris.
I have 2 cameras, Amcrest IP8M-246EB-28MM set to record continuously, with emails sent on motion.
Doubt that it is a problem, but just seems weird that it keeps re-occurring in my log file, so just wanted to see if anyone had a clue. I searched the help and google with no results.
It seems that these forums are more active so I figured I'd have better results here! Thanks, I go that route.
Not very helpful, but here is their response:
"Perhaps a monitor is being connected, disconnected?
It should not be anything to be concerned about really.
Thanks"
I know my monitors go to sleep after 30 minutes, but they shouldn't connect/disconnect that many times....
Thanks"
I have none of those messages in my log and my monitor goes to sleep. Could this be from a dual monitor setup issue ?
I do have dual monitors, I usually keep Blue Iris up on the right monitor and do stuff on the left monitor. When the monitors go to sleep it does move Blue Iris to the left screen, maybe that is what it means.
Do they run same resolution ? Could be the "change" the message refers to.
Yes, they both run at 1920x1080.
