Mounting the 2332 on cedar shingle
105437
BIT Beta Team
Jun 8, 2015
2,242
1,090
One of my 2332s will be mounted on the side of my house on a cedar shingle. Will it be a problem that the shingle is on an angle and not perfectly vertical? Will I be able to adjust for this?
Thanks @fenderman... good to know I can adjust for this because a 10° camera tilt on the vertical axis would get annoying to me after a while.
Not only can you adjust for 10 degrees, but you can for 90. I have one of those cams on an overhang parallel with the ground and another mounted on a wall perpendicular to it.
Reactions: 105437
@LittleBrother... good to know. In my case the perpendicular mount is on my cedar siding which has a slight angle to it as they overlap each other. Just wanted to know if I could adjust for that and it sounds like I can. If not, I was planning on cut a piece of another shingle and flipping it to allow the camera to mount on the vertical axis.
