My Dahua IPC-HDW4433C-A died
emersonvier
Apr 29, 2017
124
39
IL
Hi all, my Dahua IPC-HDW4433C-A(bought Feb/2018) died, I removed the power for 24 hours connect back did not work, I can not ping the camera, I can not see on my router, so do you guys have any advice?
Reactions: djernie and Arjun
Contact Andy, he'll hook you up with a better camera that will make you want to take your old camera to Best Buy for recycling :p
Not kidding, you'll be better off with Starlight :)
Reactions: Flintstone61
Hi @emersonvier
Does the IR leds turn on in low light conditions?
How does the RJ45 connectors look?
Try powering it from the barrel power connector. ( if you have an appropriate AC/DC adapter )
You got 2 years service out of the camera to weigh against what it cost. 2 of my 9 chinese market cameras have died after a few years. For what they cost I was willing to take that risk, plus non-chinese market cameras have died too. My cameras have to endure -20F to 100F temps, so IMO a failure here and there isn't shocking. Over those few years, the 2MP starlights and the new 4MP cameras have come out, so I see it as a great chance to upgrade to the better sensors. Go for a 2MP starlight or better yet one of the 4MP 5442 series. If you go for a 5442 be aware the the bigger sensor significantly changes the FOV. A 5442 with a 6mm lens has a FOV pretty close to the 3.6mm lens with a 1/3" sensor.
IPC-T2431T-AS, this is good to go!
I have this one and i am pleased with it, great price and has a microphone. All the settings are factory and i have added brighter lighting to help night time video.
Bigredfish did a review on this model.
Take it apart and see, if there is no water damage inside.
I'm pretty damn impressed, especially with that price :D I'll have to start recommending to folks asking me about budget cams
Reactions: djernie and mat200
If you've still got it, I'd buy it for parts. I've got 3x of them and wouldn't mind having one to screw around with a little 'less careful' for flashing.
Sorry, I forgot to post the solution here, I do not know what happened but I have IP conflict, I remove the camera open a case, reset and start the setup again, work well.
Did you do a firmware update recently?
