N55DU82 Firmware advice
tmxv4128
Jan 28, 2022
370
905
California
I have several 5442T, Color 4K-X, and N55DU82 cameras installed at my home and realized that four of the N55DU82 cams have dissimilar firmware versions. I would like them to use the same firmware. The most recent firmware on one of the cameras has a build date of 1-22-2021. When I went on the Dahua site this morning and searched for firmware releases for this camera, on different website pages, two firmware versions are shown 1-22-2-21, and a newer 3-7-2023. Wondering if I should update all the cameras to the 2021 version, which I know works ok, or should I flash them all to the newer 2023 version.
You really need to be asking yourself why are you updating? If it is just for grins and giggles or OCD behavior to be running the latest firmware or have all of your cams on the same firmware, think twice.
A common theme around here is don't fix what ain't broke. If the unit is working and meets your needs, in many instances an update breaks what you had working and provides you with something you didn't need or bricks the camera. In most instances, updates are simply security vulnerability patches (usually years after the breach was found), but since we do not give our cameras internet access, the update is useless to us.
Unless the release notes specifically mention it fixing a problem you are experiencing, more than likely it won't fix an issue and may make the camera worse by removing functionality.
Here are issues I have seen people report here where they were upgrading just for the sake of upgrading:
  • Dahua 5241E-Z12E that someone updated and then constantly reboots.
  • Dahua 49225 and 49425 PTZ that Dahua intentionally removed autotracking with an update to force people to buy the more expensive PTZ.
  • Hikvision DS-2DEA425IW-DW PTZ that Hikvision intentionally removed autotracking with an update to force people to buy the more expensive PTZ (*V5.7.3 220315 -Remove auto-tracking functions on DE4A).
  • Hikvision ANPR camera losing half the FPS and loses the ability to read US plates - those are big deals to have happen, especially if you live in the USA.
  • Hikvision ANPR DS-2CD4A26FWD camera that lost all ability to read plates - kinda makes a plate reader camera useless.
  • Hikvision camera that the user lost ability to control the LED light function at night.
  • Hikvision DS-7616NI-Q2 NVR that has the APIs changed. This is a big deal if you run automation.
  • Hikvision DS-7616NI-K2 NVR that loses basic functionality when updated.
  • Hikvision wifi camera that loses the ability to use wifi after a firmware update and was intentionally removed due to too many complaints that the camera was dropping signal.
  • DH-DB61 Doorbell that loses API functionality. A big deal for someone with automation.
  • DS-2CD2387G2-LU that loses API functionality. A big deal for someone with automation.
  • Hikvision iVM4200 v3.8 - loses the free ability to use the computer as storage and now need to subscribe.
  • Dahua IPC-HFW1320S that started phoning home using 60MB/hr and costing someone thousands of dollars in data overages when he got his next mobile bill.
  • Dahua 5442 that will not allow playback of the SD card.
  • Dahua NVR58XX-4KS2 that had custom protocol (ability to add a camera via RTSP) removed possibly to force people to purchase same brand cameras.
  • SmartPSS that intentionally removed the ability to use the Intercom for those with VTO devices after firmware version 2.02.08
  • Countless other instances where the camera or NVR simply bricked and became useless.
  • Countless examples where the camera or NVR went into Chinese.
  • Manufacturers are now preventing their equipment to be updated with an older working firmware after it was updated to a more recent firmware.
Don't do it unless it is fixing a problem you are experiencing or adds a feature you really need.
Another thing to consider is that the same model could have different firmware for different chipsets used during the life of that model. So you run the risk of bricking if you do not know what chipset you have.
Here is an example - the HFW3549T1-AS-PV is available in 2 versions of firmware across 3 different chipsets for the same model camera:
  • HFW3549T1-AS-PV-S4 uses the HX3XXX-Taurus firmware.
  • HFW3549T1-AS-PV and IPC-HFW3549T1-AS-PV-S3 use the HX5XXX-Volt firmware
In this instance, Dahua added an S# designation after the model number (while Hikvision adds a C), but many do not and then you try to update with a firmware not compatible with your chipset and potentially brick it.
Further, it is best to obtain any firmware updates from the vendor you purchased it from so that you do not run into issues. Any firmware you find here or elsewhere is obviously proceed at your own risk. We have many threads here where someone tried an update with a firmware they found on the internet and bricked their unit.
Weird things happen with updates, which is why most do not do it unless it is known that the update will provide something they need and not break what they had working.
A couple months ago I was bored (even though I have more than enough to do LOL) and even though I say don't fix what ain't broke often, I thought "hey let me update a perfectly working camera to add 2D and 3D noise reduction that one of my other 5442 cams has" and totally effed up the camera. Lost the ability to set FPS and encode and bitrate and couldn't factory reset from the GUI. Fortunately I was able to figure out the API to factory reset (instead of having to get out a ladder) and had the previous firmware already (one of the reasons why I figured it was ok to try because I could revert back since I had the previous firmware), but it took awhile to get the camera operational. But even now with a factory reset several times and going back firmware, the image is much darker than it was before for the same settings.
Reactions: JDreaming
Very good advice to follow, but since I had an unused N55DU82 that I was not using, I decided to give the newer 3/07/2023 firmware a try. It worked fine. Looks like it updated a few features on the camera. I applied the update to the other four cameras, and they seem to be working well also. I definitely follow the advice not to update my PTZ software, but these cameras will someday be replaced anyway, so I didn't really care if I bricked one of them. I am still confused why Dahua posts two different firmwares for the cameras on different pages of their site. I guess they don't check both lists very often.
