mat200
IPCT Contributor
- Jan 17, 2017
- 18,922
- 31,646
Coincidentally I'm in the middle of rewiring my attic, so it would be convenient to run an ethernet cable now before I get the camera. Once I put the plywood floor back down, it will be very difficult to access the cable. Is there anything in particular that I need in a cable? Is this one ok? Amazon.com
Hi @Valle
There's a lot of fraudulent cat7/6 thin cables on Amazon .. I highly recommend avoiding them in general.
I especially do not recommend any in wall / in attic runs with garbage cable ..
If you have doubts, perhaps running 3/4" PVC stubs to appropriate areas so you can run cables in the future?
or just look for some quality in-wall solid copper wire cat5e/6 cables.
As you are running new runs, and are new to this .. I'd recommend running either the 3/4" pcv stubs or N+2 cables to each location .. chances are you will want more than just one camera in one of the positions and cable is affordable compared to your time running the cable right now during the attic work.
