- May 30, 2016
- 137
- 83
I'm trying to access BI remotely over the WAN, which I have done before but it's been a long time. I'm using NO-IP for a WAN address, which seems okay. Going through the remote access wizard in BI, all of the pages are successful (getting a green checkmark), except for the last one which actually tests the connection, which fails.
My routers address is 192.168.1.1 and my WAN address(via NO-IP) is 162.251.188.xxx:8181.
The port forwarding rule is port 8181, LAN address 192.168.1.242 , protocol TCP LAN port 8181.
I also have UPnP enabled
But when I get to the last page where the wizard performs a test it fails against 162.251.188.xxx:8181. My guess is I have screwed up the port forwarding?? Does this look right or wrong? based on the above?
Thanks in advance
Thanks in advance
