L learningtocode42 n3wb Jan 6, 2021 20 21 KY Jan 9, 2021 #21 mat200 said: What is the outer walls construction? Click to expand... Front brick veneer, sides and back vinyl. Arch on the porch is stone. Will try to post images tonight in the installation forum.
mat200 IPCT Contributor Jan 17, 2017 18,922 31,646 Jan 9, 2021 #22 learningtocode42 said: Front brick veneer, sides and back vinyl. Arch on the porch is stone. Will try to post images tonight in the installation forum. Click to expand... Brick, see if you can get a deep 1-gang box installed in the locations you need a camera, and a way to drop cat6 between the brick and the wall ( there is normally a bit of an air gap on new builds with brick faces. Reactions: learningtocode42 and sebastiantombs
