I am looking into setting up cameras at my house and after my introduction had quite a bit to look up and read about.
I am planning on getting 4 cameras to start my setup with 8 total cameras in the future and am looking for some help and advice since I have a few questions.
For inside my house I am going to get two of the Hikvision 3MP DS-2CD2432F-IW cube cameras but haven't decided on placement for them yet.
For the two exterior cameras I am looking at the DS-2CD2332-I cameras.
I was told the 2.8mm lenses would give me the most coverage but I am also interested in making sure I can have good images of faces as well.
Here is a layout of my house with some stuff to show possible camera location:
The green triangles are possible camera locations and the red circles are where someones face should be in the images.
On the front porch it shouldn't be as much of an issue since it is a large flat porch with 3 steps down to the walk way.
The back porch and sunroom sliding glass is the issue as the landing to go into the back door is up 6 or 7 steps from the ground and the sliding glass door is at ground level.
On the front porch I would mount the camera to the ceiling covering the porch.
On the back I would attach the camera under the eve in the corner where the main house and the sunroom meet so it would be slightly covered.
I don't have any good pictures of either location on me at the moment but can try to take a few shots and post them if needed.
I have looked at a few placed to purchase the cameras but I am unsure about what I am seeing on aliexpress and don't know of another seller other than amazon.
I am not sure if it would be better to get one of the Hikvision NVRs that supports 8 POE cameras or a NAS hard drive and a 8 port POE switch.
Whatever recording mechanism I get will be kept in a safe so it won't be easily accessed.I want to be able to record all cameras as well as stream as much as possible.
Inside my LAN I am not worried about the streaming but I can only get ~1M upload speeds on my DSL which is all that is offered where I live.
I would like to upload video to a cloud service as well but don't think it is feasible with my uplink speeds.
So I would like some recommendations on camera placement and options there in regards to lens choice and all.
A recommendation on recording options and pros/cons of the choices.
Help with where to purchase cameras, recorder and also the cables, crimps and tools would be appreciated.
I plan to do all the installation myself and have a walkup attic that I will be running the cables through.I think that is all for now but you never know.
Thanks,
Matt
Thanks,
Matt
