Night time settings with IPC-4K-T Help
dubber
Oct 4, 2022
226
350
Toronto
Hi All
Sorry for the troubles.
May I ask if you guys can check my settings and help me dial in the new IPC-4k-T please?
Attached are the night time setting and sample.
Currently exposure is 1/60 and built in LED light is at 22. Image brightness is at 55.
The rest of the settings like backlight\WB\Day\Night etc are all default.
No other lights turned on other then the street lights and ambient light.
Now take brightness, contrast, gamma, sharpness, etc. and adjust them to improve the picture.
For most we find that the sharpness can drop to 40-44 and contrast should be 7-8 higher than brightness.
But don't go too extreme, for example you could 100 brightness, but that will negatively impact the image as well. Most try to stay under 70, but each camera and each field of view is a little different.
