Hello all,
I have a couple of Vikviz POE IP cameras that I have port forwarded to view from a remote network. Everything works great logging in on the same network.
When logging in from another network, I can log into the cameras and I can even control the pan and tilt. But there is no audio or video stream present.
I've turned the resolution of the cameras way down and toggled between h264 and h265 encoding thinking it might be a bandwidth issue. That made no difference.
Searching for the issue online brings possible connection or cabling errors as a result. Or even incorrect port forwarding. But as I mentioned I can control the camera just not view or hear the stream.
As always, any help would be appreciated.
