ONVIF rule criteria for triggering events in BI
105437
BIT Beta Team
Jun 8, 2015
2,242
1,090
If my Amcrest AD410 doorbell camera is providing this information for when it detects a human at the doorbell. How would the BI ONVIF rule need to be created in order to trigger BI for the event? In BI, the camera shows that the ONVIF event status is "ok". Thanks
Nothing I've tried works so far. I've tried "includes" 00000, true and ObjectsInside. No trigger for those.
It's been a while since I've looked at that stuff but I'd think that the IsInside:true would be picked up by the default BI ONVIF trigger at the end of the list under the ONVIF Config button that says RuleEngine/FieldDetector/ObjectsInside with Attribute IsInside="true"
Is there a green check mark next to that line and profiles right as appropriate for whatever is active?
What does the BI log file show when you activate that cam/trigger? If it's picking up the ONVIF event/trigger, then it should show something like:
0 6/1/2024 12:12:54.397 AM CAMERA_NAME ONVIF Event: RuleEngine/FieldDetector/ObjectsInside (IsInside="true")
What control do you have over the rules in the Amcret cam? Can you name them? If so, then try naming it and then creating a new BI ONVIF "Listen for: line and in the Contains put that name with action Trigger.
Reactions: 105437
Thanks for your help @Mike A.. This is working now.
Reactions: Mike A.
Would you be so kind as to post your setup? I'm running the Lorex 2K video doorbell (same thing as the AD410) and I'd like it to record on human detection (rather than on everything, including moving branches, as it does now).
I'm unfamiliar with ONVIF events in BI, at least setting them up as a trigger (instead of using the Motion Sensor built in settings).
TY
EDIT:
I don't believe the Lorex2K video doorbell supports ONVIF, like the Amcrest - can anyone confirm? I am not getting any ONVIF events at all.
