- Dec 21, 2015
- 51
- 11
I just wanted to share something I found when looking through my alert logs. I use Dahua cameras with built in AI and I setup AI with triplines and then turned off all other motion detection. In BI I set to ONVIF triggers and thought that would be good enough. I kept seeing these triggers that were from general motion not from tripwire so I went into configure under ONVIF and unchecked everything except the tripwire trigger. Huge difference, I didnt expect to have to do that. Hope this helps someone out there.
