Opinion on camera model -- bullet vs turret
SpacecoastBill
Jan 10, 2015
93
37
Central Florida
Im looking at one of these models for my outdoor cameras, any opinions ?
They are for use in the USA.
Hikvision IP Camera 4MP DS-2CD2T46G2-4I AcuSense DarkFighter PoE IR80m Bullet Outdoor With SD Card Slot IP67 CCTV Security, 4mm Fixed Bullet Network IP Camera
Original Hikvision DS-2CD2T46G2-4I 4Mp Replace DS-2CD2T43G0-I5 4MP AcuSense DarkFighter Fixed Bullet Network Camera
High quality imaging with 4 MP resolution
Excellent low-light performance with powered-by-DarkFighter technology
Clear imaging against strong backlight due to 120 dB true WDR technology
Efficient H.265+ compression technology
Focus on human and vehicle targets classification based on deep learning
Water and dust resistant (IP67)
100% New and Original Hikvision with LOGO
Support upgrade
Original English Version
2.8 or 4mm lens.
Hikvision 4MP ColorVu POE IP Camera DS-2CD2347G2-LU Support POE IR AcuSense Full Color image and Built-in Mic, H.265+ IP67 Outdoor Waterproof Fixed Turret IP Camera,4mm Lens
COMPARE OPTIONS
2.8mm Lens
4mm Lens
DS-2CD2347G2-LU
4 MP ColorVu Fixed Turret Network Camera
Clear imaging against strong backlight due to 130 dB WDR technology
Built-in microphone for real-time audio security(-U)
24/7 colorful imaging
100% original upgradeable
multi language
Or maybe this model due to the IR ?
DS-2CD2386G2-I(U)
The important thing is to chase sensor size, not MP, and select the correct focal length for the distance you want to IDENTIFY. The cameras above are not on the ideal MP/sensor ratio.
Take a look at this thread that identifies the most commonly suggested cameras based on distance to IDENTIFY. In some instances, 2MP is the better option. The cameras suggested in this thread represent the best value in terms of performance (night and day), proper MP/sensor ratio, and cost.
Since you linked the ColorVu, I wanted to point out that many people have come here after buying the Hikvision ColorVu series expressing their disappointment in the picture quality of the camera because they were expecting magic. It is worth repeating LOL - if you do not have ambient light outside or do not like the white LED lights on, you are better off with cameras that can see infrared. ColorVu type cameras cannot see infrared, so you can't add infrared later.
Further, it's onboard white LED lights are not as bright as the white LEDs on the 4K/X.
There seems to be more posts started here with complaints about the Hik version at night than the 4K/X. If you want a full color, the 4K/X is a better choice.
Or maybe the people that buy the Hikvision version are naive and think they are magic and the ones that buy the 4K/X are educated as to the proper placement for this type of camera LOL...
Here is link to a thread of many that shows the disappointment of many thinking a ColorVu camera was magic and could defy physics. Full Color type cameras are great if you have light, but will be horrible if you do not have enough light.
Support upgrade
2.8 or 4mm lens.
COMPARE OPTIONS
2.8mm Lens
4mm Lens
DS-2CD2347G2-LU
multi language
3rd party seller on Newegg ..
DS-2CD2347G2-LU
remember to double check the specs as the seller is not providing them ..
Reactions: JDreaming
