In the earliest stages of my install and I followed the instruction to set all of the cams to substream/direct-to-disk/continuous. (To be frank, I'm concerned that this will significantly degrade capture quality, but it is untested in my case, just yet...but I digress) what I actually need help on is in the very first section of the optimization instructions. There is a non-sequitur that I need to clear up. The instruction says:"When you use Direct-to-disc, it is strongly-recommended to also have the camera embed its own timestamp into the video stream (otherwise the timestamp will not appear in a recording until you export it). " And then, that tidbit hangs there with no instruction on HOW this is enabled. I need it "Explained like I'm 5". Where is the option or check box to enable this, OR is that something that has gone away in BI Updates? (I'm a brand new BI user (licensed, ver 5.3.X u/d yesterday using new Dahua cams)
