I initially posted at the end of June about input on different camera locations. Here is that link:
ipcamtalk.com
Well, unfortunately, life got in the way and I wasn’t able to install anything. Have I mentioned how hot an attic gets in July/August in Missouri??
. I’m now at the point that I’m ready to start running cable and installing cameras. I’ve run tests at most of my locations except for 1. We have an atrium ranch. The back of the house is basically 2 stories because of the walkout. Because of this height, I haven’t tested a camera at soffit height for that location. What are others doing in similar situation? Are you running an overview that high? I can install lower, basically between the floors. That portion of the basement isn’t finished yet so access is pretty easy. Any particular preference or if anyone found one option better than the other? Will a 2 story overview still be effective?
Thanks!
Erick
Camera Placement Questions
Hello all! First, I wanted to thank everyone for their help with my questions thus far. The expertise and willingness to help on this site is amazing and greatly appreciated. I ordered my first camera today, an IPC-T5442T-ZE. My plan is to use a test rig (like mentioned many times here) and...
. I’m now at the point that I’m ready to start running cable and installing cameras. I’ve run tests at most of my locations except for 1. We have an atrium ranch. The back of the house is basically 2 stories because of the walkout. Because of this height, I haven’t tested a camera at soffit height for that location. What are others doing in similar situation? Are you running an overview that high? I can install lower, basically between the floors. That portion of the basement isn’t finished yet so access is pretty easy. Any particular preference or if anyone found one option better than the other? Will a 2 story overview still be effective?Thanks!
Erick
