mat200
IPCT Contributor
- Jan 17, 2017
- 19,020
- 31,829
This is good and expected. Still a lot worse than flu, but better than earlier numbers.
But one note of caution: the term CFR means Case fatality rate which means only diagnosed cases can be included in the numbers. Asymptomatic or subclinical individuals --who wouldn't have reported it and become cases-- aren't factored into a CFR.
Sent from my ONEPLUS A6013 using Tapatalk
Hi @Frankenscript
So working off the definition from the Dictionary of Epidemiology does not make fully clear.
The definition of the CFR in the Dictionary of Epidemiology states that it is “the proportion of cases of a specified condition that are fatal within a specified time”.
If we are working with only those clinically diagnosed with COVID-19 then the CFR will be significantly higher as not everyone will be probably diagnosed.
Hmmm.... so if I only test for COVID-19 those who go on ventilators I could get a CFR of 30-50% .. likewise if I do not test at all, then no one officially dies of COVID-19
