I’m running into an issue with PoE on a home setup. The cable run is close to 90m (Cat6, solid copper) and the camera sometimes reboots randomly. The switch is PoE+ (802.3at), and on paper it should be fine with the camera’s 12W draw, but I’m guessing voltage drop is the problem.
Has anyone here dealt with similar situations? Would you recommend adding a mid-span injector/repeater, or is it safer to upgrade to a PoE++ (802.3bt) switch?
Any real-world tips would be appreciated — not sure if I’m overthinking it or if this is a common issue.
is the cable 23AWG?
this is more important than cable is
CAT5 or CAT6...
You can try to use different switch, but POE++ will not solve any problem here (because camera will negotiate POE+ only)..
Also POE+ and POE++ are using the same voltage...
Both HIK & Dahua are offering own POE switches, for camera installations on long cable runs.. Dahua is calling this ePOE and most Dahua cams is supporting this... Also better/higher models Dahua NVRs supports ePOE on first 8 ports...
Andy is his shop have only small one (8 port), but you can easy to find bigger models with ePOE..
Estimated delivery is 2 weeks, and expedited shipping is not available. Supports long distance PoE transmission up to 800m with ePoE technology of EmpireTech. Layer-two ePoE switch. MAC auto study and aging, MAC address list capacity is 8K. Complies with IEEE802.3, IEEE802.3u, IEEE802.3ab/z and...
empiretech01.com
Is you are using HIK (or other manufacturers) cams, you should choose switch solution for that company (they aren't compatible)..
Google AI:
What is dahua ePOE?
Dahua's ePoE (Enhanced Power over Ethernet) is a patented technology that extends the transmission range of traditional PoE by transmitting power, video, audio, and control signals over a single network cable for up to 800 meters (or 300 meters at 100Mbps), greatly exceeding the standard 100-meter limit. It simplifies installation for large-scale systems, reduces costs by eliminating the need for intermediate
repeaters, and enables the cost-effective migration of old analog systems to modern IP systems using existing coaxial cables with a special adapter.
