I'm a concrete dispatcher by day. In the winter, there is not much to do. I've been in graphic design for a while, and have a sign business so I'll draw out camera layouts killing time.
My friend wants his pole barn secured. We ran Cat6 from the house to the barn a couple weeks ago. Once he was connected with all the benefits that come with it, he wanted an NVR + 2 Camera setup. He "lives" in the pole barn when home. His man cave, building 500HP+ race snowmobiles in the winter. They are pretty awesome.
I decided to go with an HDBW5231R-Z mounted inside to cover the only two entry points. The camera would be 25 feet from the garage door and 40 feet from the man door, which are all on the same wall.
Outside I decided on the SD59225U-HNI. It's about 450 feet from the camera mount to the beginning of the driveway. The DORI Identify range of this camera is 528 ft so we are hoping to cover the entrance to his property. To add to that, I'll have two PIR sensors on the far corner of the barn that would trigger PTZ presets and track motion if it occurs.
I also added two outdoor bullet mics for each camera to record sound events. The PIR's and each mic will require 12v and I believe I've laid out the wiring to achieve this. I wanted to use two open ports of the NVR to run the power to the PIR's, using an extractor at the end to power the devices.
I'm open to all criticism and ideas. This is my first attempt at a POE IP Camera install/setup. Any advice on the wiring schematic, and pros and cons is greatly appreciated.
Oh, I forgot. I have $1247 USD invested all in for the project so far.
SD
You will have to open the pics in a new window to zoom in to see detail.
SD
