I'm adding IR lights for my cameras, what is the longest length the power cord that can be used and also, can you use a splitter on one power cable to connect two lights?
Are the IR lights close to the cameras? If so, you can buy POE splitters which split the data and power into the two separate connectors (RJ45 and DC barrel connector). From there, you can further split the DC power between camera and an illuminator.
Yes they would be close to each other.
Something like this???
That's perfect. You'll need the POE splitters:
Then the y-cable to split the DC power between the cam and the IR light:
The linked splitter will provide up to 24 watts of power @ 12v (2amps). I'm assume you have the barrel connector for DC power on your cam and the IR light has the same connector.
Connect the POE splitter to the cable coming from the switch/NVR. Plug the RJ45 male from the POE splitter into the RJ45 female of the cam. Then connect the y-cable to the barrel connector of the POE splitter and then the two ends of the y-cable to the cam and IR light.
Only thing to check is the combined wattage of the cam and the IR illuminator. Both should be listed on each device. Make sure the total watts (cam + IR light) don't add up to more than 24 watts.
This is the easier way and avoids running power just for the IR light.
I was just wondering if one could use the 5.5mm x 2.1mm power plug that is already on the camera to power an IR illuminator? Of course, one would have to use a POE power injector of the proper size that is feeding the camera power through the RJ-45 connector.
Would not that diode be for blocking one feeding voltage back into the circuit?
I think it's @wittaj who has the down low on that. I measured the voltage one day and it read 11.5v but apparently that's what's leaking from the diode that's supposed to STOP people from feeding another DC device directly off the camera.
My only complaint is that the POE splitters are a bit bulky and I've had to install a junction box just for the POE splitter. I just mount it beside the junction box for the camera and have a very short piece of conduit between the two.
To clarify @wittaj 's schema, here's an image at bottom I copied from someone in another thread this morning but for the life of me can't find his post or even his name....but kudos to him.
EDIT: I found it here. Thanks @Mark_M !
And BTW, if you can get the one wiitaj linked, here another 2AMP version ==>> Gigabit PoE Splitter 12V 2A Output with IEEE 802.3af/at Standard Compliant 10,100,1000Mbps Power Over Ethernet Splitter Adapter for Security Camera CCTV Surveillance 5.5x2.1mm DC Plug Cable(PS5712TG)
You said earlier that the cam and the IR emitter are close to each other.Solving one issue but creating another one. Now I am faced with finding a way to protect the 12v splitter as it won't fit inside the box I have the camera mounted to.
