Hello,
I have a Dahua IPC-T5442TM-AS 4MP set up that's been showing a blurred video which seems to be getting worse by time. You can see a screenshot of the camera visual in the attachments.
Things I've already checked and tried:
Thanks
- Checked the stream from both Blue Iris and directly from camera (main and sub)
- Played around with various settings and defaults - also reset the camera to default
- Cleaned the outside of the camera
- Removed outer casing of the camera and cleaned inside lens - removed any dirt
Thanks
