PTZ LPR Help
jd415
Jun 1, 2019
354
1,100
Los Angeles, California
As some of you know I use a PTZ as a long range (almost 200 ft) LPR. My old PTZ the shots look great however with my new PTZ they look a little pixelated. I've tried adjusting the settings and that didn't help either. If you look carefully at the video when the car comes into the shot the video gets a little dark for a second and goes back to normal. I've included images with my old camera, new camera and also my settings. I hope it's just my settings I set wrong and not a limitation of the new PTZ.
Was hoping someone here can help, tagging a few of you just in case you don't see this post. Thank you!
@wittaj @Parley @bigredfish @lulu5kamz @samplenhold @TonyR
Old camera 4MP 1/2.8"
New camera 4MP 1/1.8"
  • Video.mp4
    Video.mp4
    7.4 MB
Thats normal on some cameras with some settings. The camera is auto adjusting Gain within your specified limits. Its actually beneficial most of the time in that on a bright sunshine day, it can help reduce glare. I run an exposure range during the day and see it.
I think the only way to eliminate it would be to set a fixed range on Gain like 50-50, but that will create other undesirable effects depending on the light and object. Objects it sees as "close up" ie heavily zoomed" that take up a lot of the scene seem to set it off
+ 1 all of above. The bigger sensor lets in more light than your older one, so it probably have a bigger range spread.
We had another post just this week talking about it:
I tried adjusting the gain and it didn't help. Is this just the way this camera is? If so I guess I will switch back to the old one but I'm really trying to avoid that.
So I did some testing today using the 5442-Z4. Seems the newer cameras (possibly all 1/1.8" sensors but certainly the S3) auto adjust both Exposure and Gain by themselves, as expected, if you set a range on either. Not necessarily a bad thing, but if you're using the camera for a purpose such as LPR, probably best to use fixed values for both Exposure and Gain.
It tries to compensate both ways, brightening the image when the scene becomes darker and darkening it (or ignoring it) when the scene is bright.
Normal settings: Exposure 0-2, Gain 0-50
(2 vehicles, wait for it)
View attachment Exp-0-2-Gain-0-50-Home_ch8_20240529123155_20240529123227.mp4
View attachment Exp-0-2-Gain-0-50-Home_ch8_20240529120128_20240529120134.mp4
@bigredfish those videos look amazing! Crystal clear!
I adjusted the gain and the images are still not clear like the old camera. What am I doing wrong?
Well my tests were with a z4 zoomed in more than you and my targets are quite close- 45-55ft
Cut DNR back to 30-35 , back off brightness to say 46, increase contrast to 55, and back sharpness down to 35-40
The one problem you’re facing you can’t fix is the FStop if your PTZ zoomed in. FStop goes way up (less light allowed in) as you zoom a PTZ.
I think your image looks fine, but part of the pixelization or artifacts you’re seeing is something all of the 4MP 1/1.8 sensors seem to have a problem with. Cutting sharpness back can cure some of it
Reactions: jd415
