Pushover working but two issues I am hoping to resolve
Rob2020
Oct 2, 2020
1,098
2,738
OR USA
Hello all, I have had the pushover app on Android since 2022. At one time I always received a GMail with picture along with the push notification. I no longer receive GMails with Pushover. I seem to recall Google started discontinuing support for "less secure" apps? Is there a fix for this, Zapier maybe?
The second issue, when using Pushover, if I walk in front of a cam and get a push notification, I only get a single push notification if I remain in the area of motion. Previously, I would get repeated push notices until I left the area. The continued push's really catch your attention vs. one easy to miss push notice. Thoughts?
Server is WIN 10 with latest stable BI version, Pixel 7 Android client.
If you make an app password in gmail it will still work.
If you want notifications for as long as you are in the field of view then either make the duration time shorter or use the "New zones/sources only (additive)" option if you are going to have several rules being used in one camera and want to be able to do something with each rule separately or want multiple alerts within the same area. This will also generate multiple triggers.
Reactions: Rob2020
