no power at all...but there is a light pole by the gate (owned by the Electric Company) and maybe I can get current from it so, what if I can???Is it safe to assume there is no power at the gate?
maybe I can get the camera closer to the gate (solving the power issue) but what about ethernet cable??? is a very long distance...Hi @Gaspar
See the Dahua Q3 catalog pages 62-65
Dahua Q3 Catalog for the IP Video Product 201808
This gives you some idea of what Dahua claims for DORI distances.
Personally I think they are being optimistic, for example we typically use 100 ppf ( pixel per foot ) for a guide to determine ID distance, and Dahua iirc uses about 75 ppf
Thus I would expect better performance if you take their DORI numbers and cut the range by 25-33%
At 400M I think you will need to look at the various PTZ models that have better optical zoom.
Instead of the long Ethernet cable, if you have line of sight you could install a Layer 2 Transparent Bridge with a couple of Ubiquiti 5GHz radios, like this below:maybe I can get the camera closer to the gate (solving the power issue) but what about ethernet cable??? is a very long distance...
thank you very much @TonyR, I was thinking something like that...but here´s the thing: if I can get the camera close to the gate then the distance between it and the NVR is about 1.1 Km (with LOS) so my question is: instead of the PtP link can I use a wireless camera (maybe Hikvision) and a sector antenna with an Ubiquiti radio in the NVR´s side???
clear like cristal!! thanks @TonyR, I´ll work on my project and get back here for updates!!
Sorry, one more question: for that distance (over 1 Km) can I still use the NS Loco M5 ???
Why not just run fibre optics stability and introduce media converters at both ends
I see this a reliable, long lasting solution as opposed to Radios
+1 for fiber! Your switch may already have an SFP uplink port...
you´re right @TonyR!!!Oh, fiber's great! But I doubt the OP wants to put in over 1 Km / 3,300 feet of it.![]()
Have you considered long term needs.Radio getting fried, wireless issues,need for occasional reboots etc.
For me, hardwiring is my option for any project especially when I know its possible. This reduces my maintenance costs greatly
