Hi there,
Ive finally uninstalled iSpy and Have now purchased BlueIris 3.66 for my HP Gen8 Microserver
Server Specs:
OS: WHS 2011 64bit server running on a SSD
CPU: i3-3230T
RAM: 4GB DDR3
HDD: 2TB WD RED NAS Drive. No Raid. 1TB partitioned for BlueIries
As BlueIris is a 32bit application, i see no need to increase the RAM, but am open to it if this will improve performance.
I have a single POE Hikvision DS-2CD2132-I - Set to 1080p , Variable Bitrate. 6 Frames per second.
In Blue Iris , i have the Camera set to 10 frames/sec and with a 1.5mb buffer in Video , Network IP , Configure, Network Options.
Is there somewhere i can set it to record earlier and designate a record length ?, as i appears to not capture the first 2 seconds of what should be recording......
Any advice on further configuration would be great. Most of the Motion/Trigger page make little sense to me as a new user. If anyone has a cheat sheet to what each option does, that would help.
Thanks again,
Mark.
Server Specs:
CPU: i3-3230T
RAM: 4GB DDR3
Thanks again,
Mark.
