- Aug 7, 2017
- 418
- 226
Dahua actually has a pretty decent 60mm fan installed in their NVR for expelling heat. But if you're not using all four hard drives like I am, then you're much better off re-purposing the 60mm fan and mounting it on top of the CPU itself.
This default fan location is mounted so far away from the motherboard that I began to wonder its effective usefulness. I find that I can repurpose this fan right on top of the CPU since the CPU has no fan. I am also no longer using the original NVR case because it is way too big and I will never have four hard drives. I have since transplanted all the components into a ITX case.
The fan is a 4-pin PWM and is dynamically adjustable by the NVR firmware when it needs more cooling or less. On boot-up, the fan is definitely loud, but shortly when it boots into the OS, it becomes pretty silent. Without the fan, the CPU heatsink can get pretty very warm but not burning hot. WIth the fan on top, it is nearly ice cold now.
The bolts are M3 x 45mm.
