RESOLVED: Deepstack, Unable to Connect and/or Path not found
Wen
Aug 24, 2015
94
31
Well, I've spent about 16 hours trying to get deepstack to run. I had it working three days ago and then I lost contact with the Deepstack server.
I uninstalled and closed all of the Deepstack programs that I could find in Taskmanager. I deleted the deepstach folders, and attempted to use the "Program Uninstall" for deepstack. It didn't work.
Rebooted numerous times
I tried running it with the Firewall off and no connection.
I added Deepstack rule for in bound and out bound programs
I tried this cmd script:
deepstack --VISION-DETECTION True --PORT 82
I re downloaded the CPU version 2022.01.exe and installed that. The install competed without error.
When I click on "open AI dashboard" I was getting a "unable to locate error"
I continued to trouble shoot and now I'm getting a Path Not Found error
I've opened up Port 82 in the firewall
I check and added the second exe file to the C;\deepstack\server folder, see attachment
I have been unable to authenticate the Deepstack server. I do get the Nothing Found in the alert clips.
I'm going nuts on this. I read and re-read all of the Deepstack posts that pertain to these issues.
I tried to find the 2020 or 2021 version of Deepstack, but even though I searched high and low I was unable to find it.
I appreciate help looking over this post, if you need any other info please advise.
Thank You!
Also, I tried to download the Code Project exe file, and installed it. The AI tab in BI 5 (5.8.5.8) is still populated with the current Deepstack information. I don't know how to completely delete the old deepstack info that shows up on the AI page.
A forum member sent me a pm with his settings. I noticed that under the AI tab, I had C:\deepstack\server. and his showed C:\Deepstack.
I changed mine to mirror his, and it's now connecting!
Thank you Wittaj!
