Review-Dahua PSDW5631S-B360 panoramic 360 camera.
looney2ns
IPCT Contributor
Sep 25, 2016
16,907
25,276
Evansville, In. USA
Dahua PSDW5631S-B360 from EMPIRETECANDY
3x2MP Multi-Sensor Network Camera+PTZ Camera
Review unit courtesy of Andy (@EMPIRETECANDY) in exchange for a fair and honest review.
Andy's ipcamtalk vendor forum: link
Andy's AliExpress store: link
Andy's Amazon store: link
Andy's Email: kingsecurity2014 (at) 163 (dot) com
Price Approximately US $300.00
Link to camera on Andy's AliExpress store: US $299.99 5% OFF|Aliexpress.com : Buy PTZ Camera PSDW5631S B360 3x2MP Multi Sensor Network Camera+PTZ Camera ,free DHL shipping from Reliable Surveillance Cameras suppliers on Empire Technology Co., Ltd
(price and link valid 07/11/19)
> Panoramic: Three 1/2.7” 2Megapixel progressive scan CMOS
> PTZ: One 1/2.7” 2Megapixel progressive scan CMOS
> H.265/H.264 dual-stream encoding
> 25fps@1920x1080
> Support 360-degree panoramic view
> Day/Night(ICR), 3DNR, AWB, AGC, BLC
> Max IR LEDs Length 15m
> Micro SD card slot, up to 256GB
> PoE+
Panoramic Camera
Image Sensor Three 1/2.7” 2Megapixel CMOS
Effective Pixels 3x1920(H)x1080(V)
Scanning System Progressive
Electronic Shutter Speed Auto/Manual, 1/3~1/100000s
Minimum Illumination 0.03Lux/F2.2( Color,1/3s,30IRE) 0.2Lux/F2.2( Color,1/30s,30IRE)
0.03Lux/F2.2( B/W,1/3s,30IRE) 0.2Lux/F2.2( B/W,1/30s,30IRE)
IR Distance Distance up to 15m(49ft)
IR On/Off Control Auto/ Manual
IR LEDs 6
Panoramic Lens
Lens Type Fixed
Mount Type Board-in
Focal Length 2mm
Aperture Type Fixed
Max. Aperture F2.2
Angle of View H: 136˚, V:78˚
PTZ Lens
Lens Type Motorized
Mount Type Board-in
Focal Length 2.7mm~13.5mm
Aperture Type Auto
Max. Aperture F1.8
Angle of View H: 105.9˚~33.3˚, V: 56˚~18.7˚
Optical Zoom 5x
Full spec sheet:
Quick start guide:
NOTE, this camera is intended to be used indoors only. It also is not Starlight. It may survive if used in well protected areas outdoors, but do so at your own risk.
Connections for audio in/out, RS485, Alarms in and out. Power if not using the POE+, Ethernet.
Camera has a builtin mic, but you can add your own with the connection shown here.
SD card slot below the audio in/out jacks.
Mounting plate, mount plate to ceiling, then camera snaps into plate.
IMG_20190710_165458065.jpg IMG_20190710_165505212.jpg IMG_20190710_165550035.jpg IMG_20190710_165621482.jpg IMG_20190710_165708086.jpg
Red arrows point to the 3 side cameras.
EDIT 7/12/19: I just noticed this embossed on the mounting plate. It does indeed fit a single or double gang box.
Ok, so I struggled on deciding how to show off the features of this camera. This is the way I cam up with, I did a screen capture with VLC.
When the PTZ moves, I have clicked on a spot in one of the other 3 camera views, that triggers the PTZ to go to that same spot.
You can also notice that I draw red squares that cause the camera to pan and zoom into the spot I outlined.
I have all four of the cameras working in:
Blue Iris
TinyCampro
Chrome with IE tab.
It tries to work without the plugin, but I've had no success, just get a black screen.
All you need to do is to change the channel number to the camera that you want to add to BI or Tinycam.
Note I added another picture to the OP, that shows that it will fit on a single or double gang box.
Don't judge my junky ass garage. ;)
The camera is mounted at 8ft, measured to the base of the cam to the floor. I hope these videos make sense to everyone. I would guess in a store setting or such, that it would be better mounted at 10-12ft from the floor. YMMV.
So what are we going to call this one? The zebra?
And since Dahua seems to keeps increasing the amount of sensors in the cameras, when can we expect this to be released?
Sent from my iPhone using Tapatalk Pro
Might have to look into this in my 2 car garage woodshop to catch various angles & locations while doing some wood working.
Here ya go Looney... just thought of some drill organization for ya :)
If you use a double gang box to attach the B360 plate to the garage ceiling, what method is there to orient the three fixed direction cameras? Is it simply that you get what you get? I was going to put a single turret camera located to one side of the (yet to be built) garage, but now thinking about using one of these and presume that it is a 120 degree offset "Y" pattern, and all I can do is chose to attach it with the base of the "Y" to the north or south (if that makes sense). Thinking that if I put it about where the windshield of one of the parked cars might be located (on the blue prints of the garage) and guess what the three fixed cameras will cover for side doors, etc. Thanks.
The orientation of the mounting plate determines what the fixed cams look at.
Yes. And the mounting plate is attached to a junction box attached to a stud on the garage ceiling? Or is there another way to attach the plate to the drywall ceiling such that I can optimize the orientation?
Other way would be to mount a cover plate on the box, then drill holes in the plate that will allow you to align the cam the way you like.
Reactions: VorlonFrog
A month later...do you still dabble with this camera? I am thinking of pulling the trigger for this. However, reading up on your Boobie Cam review, there are issues with the channel selection and one of the cam's unable to motion trigger.
I assume, this would be a 3 channel camera?
4 Channel. I've had no issues with it.
The boobie cam is mounted outdoors, I use Blue Iris, so it works fine for me.
Reactions: EMPIRETECANDY
A true 360 degree camera? Offers panoramic 360 degrees :D
A Starlight version would be nice
@looney2ns what does this look like mounted to the ceiling? If you still have it up can you add a pic?
How far soes it hang down from the ceiling? (Overall height of the device?)
