All, thanks to Andy (@EMPIRETECANDY ) we have a new heavy duty, hardcore 4K PTZ AI camera for testing. This camera has been provided by Andy in exchange for a fair and honest review.
This test is of the SD8A840WA-HNF 4K 40x Starlight IR PTZ AI Network Camera. This PTZ is based on a 1/1.8” sensor with 5.6mm to 223mm focal length 40x optical zoom. While this AI PTZ does not offer the newer SMD plus it DOES offer Face Recognition (including in cam), Deep IVS & Object filtering as part of its AI features. These and many other features I will be testing in this review.
Please note this is a Hi-POE camera therefore requires up to 50w power so WILL NOT work on regular POE+ switches. Either PFT1200 midspan or Hi-POE / 802.3at supporting switches will work with this PTZ.
I will be covering configuration, AI setup for critical capture, tips and tricks on how to best utilize and obviously a rundown of image quality in day/night capture scenarios, really pushing this sensor to its limits.
Full specs below and will be adding initial pics & vids in post 2, AI feature breakdown and testing in post 3, tips and tricks on how to make these features work and other settings / menu functions in post 4 and a summary of findings / recommendations in post 5.
As always, if anyone has any questions as I go just leave a comment.
Links
Andy’s AliExpress Link
https://www.aliexpress.com/item/4000328442332.html?spm=2114.12010612.8148356.7.7b2046f2f9YBjy
Andy’s Amazon Link
To follow later
Andy’s PFT1200 Midspan adapter Link
To Follow later
Camera Details
Image Sensor - 1/1.8” STARVIS™ CMOS
Effective Pixels - 3840(H) x 2160(V), 8 Megapixels
Electronic Shutter Speed - 1/1s~1/30,000s
Minimum Illumination
IR Distance - Up to 500m (1640ft)
IR LEDs - 10
Smart Wiper
Lens Information
Focal Length - 5.6mm~223mm
Max. Aperture - F1.4~ F4.8
Angle of View
Optical Zoom - 40x
Close Focus Distance - 100mm~ 1000mm
DORI Distance
So lets jump in with some pictures but rather than just pics of the cam itself, I thought it would be good to compare size of the unit vs 49225, 59xxx series (more to come on this one in pic) and the 4K. So here you are
The lineup for comparison
Couple of profile images of the 4K
2 pics of the PFB306W that comes with the camera. This thing is a little longer than the usual 305 (needed as gives more clearance from a wall if installing with the arm and a PFA120) and has a VERY useful little door that you can unscrew to gain easier access to the cabling.
Little tip here, when installing using the 306W pull CAT 6 cable run from your wall / conduit through this hola and leave hanging down. Then install the cam to the arm and as you feed its connector along drop it through the same hole. Then after securing the cam with the carabiner and chain you can a) pull excess cam cable through the hole (so you can attach cam to the mount more freely) and b) when you are securing and weatherproofing the cable connect you have both in easy reach of the opening and can push back into the space easier when complete.
Spec Sheet For Full Details
Attached to post
Links
Andy’s Amazon Link
To follow later
To Follow later
Camera Details
Color: 0.002Lux@F1.4
B/W: 0.0002Lux@F1.4
0Lux@F1.4 (IR on)
IR LEDs - 10
Smart Wiper
Lens Information
Angle of View
H: 63.9° ~ 2.0°
V: 37.2° ~ 1.2°
D: 71.2° ~ 2.4°
Optical Zoom - 40x
DORI Distance
Detect - 4400m(14435ft)
Observe - 1740m(5708ft)
Recognize - 880m(2887ft)
Identify - 440m(1443ft)
Attached to post
