Rotating 90 degrees causes BI to double image
Dseg42
Apr 17, 2016
171
14
Palm City, FL
So I can figure out why BI is d oubling my image after I rotated a camera 90 degrees.
I am using the camera for my front door and is much better if I use corridor style.
But BI maintains the wide image but just duplicates the 90 degree video side by side.
Not sure if that makes since.
Might also be worth posting up which camera / your camera settings / BI settings. I have several of my cameras in hallway mode and haven't seen the issue you describe.
Post an image
The camerar is a IPC-HDW5231R-Z I purchased from Andy.
All settings are default except for rotating 90 degrees.
Below is a pic - Camera 7 is rotated but doubled.
I disabled and re-enabled the camera - it is not doubled anymore but should the camera frame be this small? Seems super, super small.
yes that is normal...
