- May 6, 2018
- 2,953
- 3,388
I've noticed in UI3 both confirmed Sentry alerts and non-confirmed (false alarms) alerts show in the alert list for specific cameras that Sentry is enabled for. I also see you can enable the "Auto Check Confirmed Alerts" in the console.
Is this the only way to filter out the false alerts in the Alert list in UI3? I'd like to pull up the camera I have Sentry enabled for in UI3 and just hit the Alerts at the top to see the confirmed Sentry alerts without the false positive alerts showing as well. Is enabling "Auto Check Confirmed Alerts" and then checking "Flagged Only" in Ui3 the only way to filter out the junk from the good alerts. Is there no way to just disable the false positives from showing in the alert list to begin with and only show the Sentry alerts with their badge?
