Simultaneous alerts in BI
rdxny
Oct 15, 2022
295
230
ny
If multiple cams see the same movement, using Motion Sensor, one may trigger and alert first, but the second, seeing the same person a couple of seconds later, tends not to trigger... even if I see "Person 90%" on both cams. I'm using continuous + Alerts, so I have video of both, but the second cam will have only the substream if not triggered, so I have lower quality on that view, even though it saw the person and confirmed it as a person, it seems like it doesn't trigger if another cam already did. Is there a setting that controls that so I can have both record mainstream on a confirmed alert? (Using cpai on both .. unsure if that affects it also?)
