SmartPSS
redfive
Apr 13, 2016
542
240
Anybody has already tried this version of SmartPSS ?
Cheers,
I have... Some interesting features, not sure if they are new or not because I don't use PSS much except to pull playback from NVR.
Smart track config and the multi track screens
** EDIT- After looking on last version of PSS on my laptop, these features are not new- just undiscovered for me..
The one on dahua wiki has a different file name and date - General_SMARTPSS-FLIR_Win32_ChnEng_IS_V2.002.0000007.0.T.190122 vs
745145_DH_SMARTPSS-Win32_ChnEng_IS_V2.002.0000007.0.R.181023
Template:SmartPSS - Dahua Wiki
Reactions: redfive
@jmcu Do you remember this ? I thought that maybe, with the new versions (SmartPSS and NVR fw, 20181229), it had been fixed ..
Yea, that's what I see too. Not able to go through NVR but direct works ok..
I would like to figure out how to change the vertical and horizontal magnification desired on the smart track.
With this version you can backup a file via Playback, to an MP4 file. The problem is I can find no way to use the scissors to cut a small enough clip so that it doesn't error out on the export. Anyone have a solution for this? The only option is a 1 hour clip, to a DAV file. If I could find a good conversion tool to convert a DAV to MP4 that would help tremendously. But most I've tried a pretty suspect, or expensive.
When you use the cut tool you can see the 1hour red flags. You can then slide the right side flag,
( at the end of the hour) and slide it to a shorter time. Then click the cut tool again.. All as mp4
You will have to expand the timeline to get the minute view.
I was able to do a 30 sec clip to 10 mins with nos issues.
Reactions: Iemand91
Thanks! Will try that today. Although to be honest, I have shortened the timeline to less than an hour before, but do not see a red flag to move, on the right. I will give it a go, again. Much appreciated.
If you dont see the red flag on the right, you will have to compress the timeline to see it. It will be at the 1 hr mark.
It is a pain everytime and if you forget, it starts to download the 1hr clip. It has been working for several versions.
Reactions: weigle2
Right again. The initial timeline has to be 1 hour or more to see the right flag. That was my problem. Works like a charm. Thanks again.
Reactions: jmcu
