[solved] TPC-BF2120 factory reset
Aug 12, 2018
6
2
Messina
good evening,
I am the owner of a TPC-BF2120 from Dahua. unfortunately I changed the password and lost the note and I can not 'access it, can you explain how to perform a hard reset? online I did not find anything. thank you,
Carmelo
I don’t know that specific model but usually if you take it apart there is a “button” inside is not very obvious where it is, but you hold the button down and apply 12 VDC / PoE power, then release the button after about 30 seconds.
also the cliff notes in the wiki at the top of the page (blue bar) has some details for resetting other Dahua cameras
Sent from my iPhone using Tapatalk Pro
Correct
When there are no buttons you have to short-circuit to solder points on the circuitboard when they don’t have a button installed
I’m afraid we have exceeded my knowledge base so will have to wait for someone more experienced to chime in.
I suggest you post a picture of the circuitboard.
Hi.
It was any progress here ?
I have model like this picture, no reset switch.\
Any hint ?
Thank you so much.
Nick
Hi, I need help ! I have a BF2120 camera that I want to reset, but this model DOES NOT HAVE a reset button like the one shown in the photo, here is a photo of the camera that I have to reset, can someone tell me how to reset it? thank you
Can someone help? Where od short circuit to reset password?
Здравейте Приятели!
Темата е малко стара, но някой намери ли начин да ресетна камерата без бутон?
Bonjour. J'ai le même problème. J'ai les 3 même caméras mais sans le bouton reset comme sur la photo. Avez-vous trouvé la solution pour reset le mot de passe ? Merci
