I submit this to the collective wisdom here, as it doesn't make much sense to me... I would assume that a higher bitrate setting on a camera implies less compression and therefore less processor load on the camera side.
This test I ran on some cheap cameras, I have not tried the same on my Dahua/Hikvision cameras, so if you consider this could be the root cause, then it would also be good to know.
1. 2x 5mp cameras running over a Ubiquiti radio link (only 20 meters, signal is very good, link is being used at around 15-20Mbps, so nowhere near capacity and latency is low on such a short link)
2. Cameras running at 15fps, H264 VBR 5120kbps -> stable
3. Instability in the framerate in BI, varying wildly between 5-6fps to 15-16fps under these conditions when:
(a) change VBR to CBR and keep 5120kbps
(b) change VBR to CBR and increase rate to 6144kbps or 8192kbps
(c) keep VBR and increase rate to 6144kbpx or 8192kbps
While testing (a) (b) and (c) above I was monitoring the Ubiquiti link and the usage was still at the same 15-20Mbps, so it seemed like the camera was not really outputting that much more data...
On the BI side, CPU usage at around 15% with many other cameras running, and network at around 80-90Mbps (it is a gigabit connection)
So I can't see bottlenecks on the network or BI components...
Is it a known fact that issues with cheap cameras can be seen also in not being stable at higher bitrates? Did I happen to find the sweet spot for mine running at 15fps H264 VBR 5120kbps??
I am quite puzzled...
Thanks
Thanks
