Struggling to dial in front door camera settings to improve quality
105437
BIT Beta Team
Jun 8, 2015
2,242
1,090
I have 3 IPC-E35IR-AS-3.6mm cameras from Andy @EMPIRETECANDY installed at each of my entry doors to the house. Clip and snapshot image capture is great at night. Daytime capture, particularly early morning and at dusk, is not so great. The snapshot image shows some motion blur and a little dark, while video capture is a little better. My current Day settings are below in the specific areas. I'm open to any suggestions for me to try and test the results. Thanks!
Can you post captures so we can see what your scene looks like?
I have the older version of this camera in my office. For Day, I am running 0-8.33 and 35 gain. You need to bring those numbers down to reduce blur, and those are especially high for during the daytime. You also want as little WDR as possible, if any. Start at 1 and increase it until you get the image you're looking for.
Thanks for the reply. Here is the FOV of one of the cameras. All of these entry points are under a covered porch, so it's always shady. I'll try your number and send a new capture.
Agree with @Ri22o
Exposure is far to slow for daytime and WDR over about 10-20max produces a lot of problems
running 0-4ms on both entrances on my 5442 and 3449 Pro
192.168.1.110_FrDoor3449H-AS-PV-PRO_main_20250711103431_@1.jpg192.168.1.110_BackDoor-5442_main_20250711103424_@1.jpg
Reactions: 105437
I would add that every camera Ive ever owned struggles at some point at dusk/dawn.
Its the nature of the change in light
Reactions: 105437
better, less blur
Try turning off WDR and try SSA
You could also try turning the camera 90* to get some of the sun out of the FOV and even it out a bit.
I tried flipping it 90°, but it said that wouldn't work due "The function cannot be supported by the resolution."
In terms of getting the most out of the camera, here is my "standard" post that many use as a start for dialing in day and night that helps get the clean captures and help the camera recognize people and cars.
Start with:
H264
8192 bitrate
CBR
15FPS
15 iframes
Every field of view is different, but I have found you need contrast to usually be 6-8 higher than the brightness number at night.
We want the ability to freeze frame capture a clean image from the video at night, and that is only done with a shutter of 1/60 or faster. At night, default/auto may be on 1/12s shutter or worse to make the image bright.
In my opinion, shutter (exposure) and gain are the two most important parameters and then base the others off of it. Shutter is more important than FPS. It is the shutter speed that prevents motion blur, not FPS. 15 FPS is more than enough for surveillance cameras as we are not producing Hollywood movies. Match iframes to FPS. 15FPS is all that is usually needed.
Go into shutter settings and change to manual shutter and start with custom shutter as ms and change to 0-8.3ms and gain 0-50 (night) and 0-4ms exposure and 0-30 gain (day)for starters. Auto could have a shutter speed of 100ms or more with a gain at 100 and shutter priority could result in gain up at 100 which will contribute to significant ghosting and that blinding white you will get from the infrared or white light.
Now what you will notice immediately at night is that your image gets A LOT darker. That faster the shutter, the more light that is needed. But it is a balance. The nice bright night static image results in Casper blur and ghost during motion LOL. What do we want, a nice static image or a clean image when there is motion introduced to the scene?
In the daytime, if it is still too bright, then drop the 4ms down to 3ms then 2ms, etc. You have to play with it for your field of view.
Then at night, if it is too dark, then start adding ms to the time. Go to 10ms, 12ms, etc. until you find what you feel is acceptable as an image. Then have someone walk around and see if you can get a clean shot. Try not to go above 16.67ms (but certainly not above 30ms) as that tends to be the point where blur starts to occur. Conversely, if it is still bright, then drop down in time to get a faster shutter.
You can also adjust brightness and contrast to improve the image. But try not to go above 70 for anything and try to have contrast be at least 7-10 digits higher than brightness.
But adjusting those two settings will have the biggest impact. The next one is noise reduction. Want to keep that as low as possible. Depending on the amount of light you have, you might be able to get down to 40 or so at night (again camera dependent) and 20-30 during the day, but take it as low as you can before it gets too noisy. Again this one is a balance as well. Too smooth and no noise can result in soft images and contribute to blur.
Do not use backlight features until you have exhausted every other parameter setting. And if you do have to use backlight, take it down as low as possible. Remember the goal of this camera is to capture faces at close distance, not what is going on in the yard - dial it in to the primary goal of the camera.
After every setting adjustment, have someone walk around outside and see if you can freeze-frame to get a clean image. If not, keep changing until you do. Clean motion pictures are what we are after, not a clean static image.
Reactions: 105437
Okay, I've settled on these settings for Day. Image is pretty good considering the camera being used. I appreciate the advice from everyone!
