- Jan 17, 2017
- 18,922
- 31,646
Hi,
I wanted to share a couple of pictures to inspire others.
A simple solution for a hallway closet "datacenter" if you find that it is getting too hot for your equipment. I recommend watching the temp and if it is exceeding 80 degrees F to find a way to better vent an enclosed space.
This is what I did:
1) Locate studs.
2) Buy a vent cover, make a template.
3) Cut drywall vent in upper part of closet to allow hotter area to vent up into hallway.
4) Insert wood ( 3.5" wide ) or drywall sections to make a nice clean wall within the vent.
5) Plaster and paint.
6) Install vent cover - paint.
7) Optional install fans - in my case I have PC case fans, which I will power from freenas PC Powersupply.
Here's a couple of pictures of the nearly finished vent - it looks slanted due to the camera angle, I did use a level - so at the right view it looks better.
This allows me to not reroute any AC vents.
This is what I did:
1) Locate studs.
