T5442T-ZE Failure Modes
Swampledge
Apr 9, 2021
219
475
Connecticut
Camera in the subject line is a bit over 2 years old. It’s main stream seems to be starting/ stopping, while the sub stream continues to chug along reliably. It’s an outdoor camera, but the connection is indoors. I initially thought it was a switch issue, because I first noticed the problem after replacing two piggy-backed 4 POE port switches with an 8 POE port switch to accomodate a 5th camera in that building. I replaced that switch with one I purchased from the ipcamtalk store, but the problem persists, only on that one camera. So I’m thinking it’s the camera. It’s easy enough for me to change out the Ethernet cable, and I’ll likely try that before purchasing a replacement camera. Just wondering if others have seen similar occurrence. TIA
